egr insufficient flow.! help.!
Old Jun 30, 2012 | 08:34 PM
6thGENvtec's Avatar
Default egr insufficient flow.! help.!
Hey I got a 2000 accord coupe 2.3ulev and i have a check engine that's been hassling me forever.
Basically I got a check engine light for a bad egr vavle. I replaced it and for about 3 days the light went away. When it returned it had a code (can't remember exact code) for an egr insufficient flow.
What do I have to do, to rid me of this cursed check engine light.?
Old Jun 30, 2012 | 09:04 PM
Refer to this thread:
https://www.hondaaccordforum.com/for...problem-48459/
Probably EGR ports, common problem if it is. But, what is your actual trouble code number?
Old Jun 30, 2012 | 10:08 PM
6thGENvtec's Avatar
The code is P0401 and when I checked the tsb's, it show how to fix it but only on v6 models and that doesn't help much on 4cyl.
Old Jun 30, 2012 | 10:32 PM
Old Jun 30, 2012 | 11:24 PM
6thGENvtec's Avatar
Thanks, and I didn't mean to offend, the links definetly answered my question.
Old Jun 30, 2012 | 11:26 PM
No problem and no offense taken.
Old Jul 22, 2012 | 05:05 PM
6thGENvtec's Avatar
Default helllp.!
So I cleaned the port put everything back together. When I started the car it had 4 codes instead of the regular po401. Now it says throttle position sensor low input, map sensor high input and its tellin me to check the owners manual for the last one. My car is runnin like poop can't get it higher than 3000rpm and it falls right back down. Please help.!
Old Jul 22, 2012 | 05:13 PM
Check that the electrical connectors for the TPS sensor and map sensor were not switched.
Old Jul 22, 2012 | 08:19 PM
6thGENvtec's Avatar
Default Fixed P0401 and now have P0108 and P0122
So I fixed my insufficient flow code now I have P0108 which is map sensor high input and P0122 which throttle position sensor low input.? Can anyone hellpp me I have to drive to workk.! What could I have done wrong.?
Old Jul 22, 2012 | 08:25 PM
I combined your other separate post.
As stated previously, check the connectors for the two sensors. I believe the MAP sensor connector is gray and the TPS sensor is blue. A lot of people inadvertently reconnect them wrong.
Rick1441
Mar 28, 2012 05:52 PM
UhOh
Nov 22, 2011 05:52 PM
Dale269
Sep 22, 2011 10:49 AM
eaking09
Apr 23, 2010 04:31 PM
sali1976
Mar 29, 2007 11:07 PM
