Electric Windows - down but not up
Old Dec 12, 2006 | 02:57 PM
dc197
Default Electric Windows - down but not up
Hi everyone
I hope someone can offer some advice to a n00b.
The elctric/power windows on my 97 accord have always been dodgy. Only one has worked fully. A problem I have just suffered is that one of the windows (rear right) winds down but not up. This is true whether I use the driver's master switch or the local switch on the rear right door.
The window will not return up, and I don't think that the motor is even pushing it at all - I cannot feel or hear anythign struggling.
Could both switches have half broken? That they turn on only down and not up? Am I right in thinking that I could bypass one of the switches and temporarily close the "up" half of the circuit in oder to wind up the window?
Could the motor have half broken and will push only down and not up?
The driver's window has never worked and when I looked inside it once I saw that the glass has been held in place (closed) with stiff wire hooked under it and attached to the door chassis. Could that have been a temporary repair by a previous owner rathet than buying a new motor/mechanism, and if so could replacing the motor or mechanism return my driver's window to me?
Grateful for any advice.
Daniel
Old Dec 12, 2006 | 03:10 PM
wayneboard2's Avatar
Default RE: Electric Windows - down but not up
I am actually just dealing with sort of the same problem. Both front windows go down great but are VERY slow going up. I took the door panels off this weekend and lubed them up and tried to find if anything was wrong. The lube did help the drivers window but the other one is still the same. I think with my accord being a 97, the motors are just going bad and will need to be replaced. Bump for more feedback from the mods or vets here.
hondadude's Avatar
you really need to get the door panel off and test for power and ground at the motor.
I'd have to guess the the wire on the drivers window DID NOT come from the factory that way.
Those cable style regulators have all kinds of problems, so the fact it goes down but not up sounds like a typical problem. The replacement regulators are around $125 and come with a new motor.
I'd say to replace the drivers and clean and lube the window run channel, the rear one might need replaced as well.
RobinsonRicer
Nov 4, 2013 06:05 PM
CFnt
Jun 2, 2013 09:59 AM
compiler
Dec 28, 2011 09:26 PM
finkjac13
May 2, 2010 05:22 PM
Antarctica
Apr 22, 2007 02:41 AM
