electrical gremlin
Old May 16, 2008 | 07:37 AM
Default RE: electrical gremlin
The 'clockspring' is a cable reel that provides electrical connections to the steering wheel as you turn it to steer. Anything attached to the steering wheel is connected thru the clockspring. If there's an airbag in the wheel hub, and/or controls for cruise control & horn, etc. Your '90 might not even have an airbag? Newer cars have stereo controls on the steering wheel, stuff like that.
If your '90 doesn't have all that stuff it might not even have a clockspring.
Old May 22, 2008 | 10:57 PM
*90accord*
Ok, so I finally had some time to figure this problem out. After reading the wiring diagram, I traced the signal wires. What I found was a loose/dirty ground bracket. It appears that my car was previously in an accident and someone tried to weld the area back together but left the conection loose. So I cleaned it, and tightened it back up, and problem solved! So if anyone else experiances this problem, I suggest looking there first. The bracket is located on the driverside next to the windshield washer fill tube.Name:  05-21-08_1337.jpg
Rob The Gas Man
May 18, 2009 10:54 PM
jcocker03
Dec 10, 2008 10:27 AM
jablaw
Nov 19, 2008 01:42 PM
idtattoo
May 4, 2007 10:19 AM
NightHawk
Jul 16, 2005 12:05 PM
