Engine dies when warm
Old Nov 22, 2018 | 06:42 PM
Justin Dreyer's Avatar
Default Engine dies when warm
1995 2.2Vtec Standard
Starts and runs fine, then after say 30 miles it stutters at an increasing rate until it dies. Pull over, let it cool and then it goes for another while.
Where do I start troubleshooting?
History
I replaced the ECU with a used one and it ran fine.
Thank you!
Old Nov 25, 2018 | 03:42 PM
Do you mean the new ECU fixed it? Or the new ECU came some time before this problem started?
After it warms up & dies, I'd check for spark. Some starting fluid or carb-cleaner into the throttle body & see if it fires up for a couple seconds. My GUESS is that it won't, which points to lack of spark, which could be a couple things for you to check in the distributor.
Old Nov 27, 2018 | 02:58 PM
The new ecu had it running fine, but now this issue. I will check thank you.
IDHONDA
Dec 11, 2012 06:39 PM
Nicolai Hobbs
Jul 12, 2012 05:44 PM
8lug
Jan 13, 2011 11:54 AM
mgabe2706
Jun 27, 2008 12:29 PM
PedroG
Aug 6, 2006 03:25 PM
