Engine hesitates when accelerating
Old Nov 11, 2014 | 08:25 PM
mike789r's Avatar
Default Engine hesitates when accelerating
Hello,
I have a 2004 Honda Accord LX. 114,333 miles. It has been great up until 1 day ago.
When I tried to start the car on Monday, it acted as if the battery was very low, turning the engine over slowly. It tried to fire a few times but just couldn't catch. I pulled my other Honda up next to it and started to hook up the jumper cables.
The other car was running, the dead car had the keys removed, and as I attempted to connect the last jumper cable I saw many large sparks. I pulled back real quick. I work with electricity and immediately thought that was a way to big spark for normal. Must be a short. Put the jumper cables away.
Got back in the car, turned the ignition on. Tested the power windows and they acted like a full battery. Radio worked too. At this time I noticed the "Malfunction Indicator" was on steady. Tried one more time to start and same thing. Had to get to work so I left it and took other car.
Today, one day later in late afternoon I tried again and it at first sounded like it was not going to but then started right up and ran fine. The "Malfunction Indicator" was still on. So I went on a small test drive about 6 miles round trip. If I accelerated slowly it ran fine. If I accelerated normal or fast, then the engine would run rough or hesitate. As soon as I let up on the gas it would smooth out.
Took it to Advance Auto for their diagnostic tests. This is what I got. I will type it just the way it was spaced on the screen:
1 of 3
61-1 * ABS
Battery Voltage Malfunction
CURRENT
P2646 * ENG
A RckrArmActCtl
Perf / Stk Off B1
VVT W/Sgl Oil Prs
CURRENT
P2646 *MOD *$09
A Rocker Arm
Actuator Control
System Performance
/ Stuck Off *(Bank 1)
Hope I gave you all enough info. If you need more, just ask.
Thank you
Old Nov 11, 2014 | 08:57 PM
The P2646 has to deal with too low of voltage from the vtec pressure switch. First, check you oil level.
Old Nov 12, 2014 | 08:32 AM
mike789r's Avatar
Forgot to include that. Oil level is at the full mark.
Thanks
Old Nov 12, 2014 | 10:15 AM
Hi Mike789r
Welcome to the HAF..
Elm04
Oct 19, 2016 10:39 PM
glennwood55cameo
May 28, 2013 07:52 PM
91boz
Mar 23, 2009 10:13 PM
moontruggy
Dec 12, 2007 04:33 PM
silverbullet00
Oct 13, 2005 01:04 AM
