Engine Light Still On
Old Nov 16, 2009 | 03:22 PM
kennilope's Avatar
Default Engine Light Still On
After cleaning the EGR ports Engine light is still one. Could it be the EGR valve need to be replace???
Old Nov 16, 2009 | 03:48 PM
Maybe, but did you reset the ECU?
The CEL won't automatically go out right away. Takes some number of drive cycles & a bunch of specific operating conditions to occur, without any more EGR problems.
Or you can disconnect the battery to clear it...
Old Nov 16, 2009 | 06:38 PM
kennilope's Avatar
When I clean the port I had disconnected the ground for 3 hours.. earlier I had the ECU clear for 4 hours... does the valve need to be clean too? because i didn't touch the valve on the EGR port and the plate.
Old Nov 17, 2009 | 06:51 AM
Well, it IS possible the valve doesn't work. Or a wiring problem. It just seems more common for the ports to be plugged.
I never owned a '94, so not real sure of the next troubleshooting steps. Look in the DIY section for links to repair manuals. Also, I think there's a thread in DIY about the EGR system.
proton8d
Sep 9, 2013 06:05 PM
brandon0409
Sep 8, 2013 11:05 AM
understand1
Aug 28, 2012 05:42 PM
HondagalGA
Apr 17, 2012 08:13 PM
olgirlkeepsrunnin
Jan 25, 2010 08:23 AM
