engine noise, AC system?
Old Jan 1, 2013 | 08:29 PM
crashdummie's Avatar
Has timing belt ever been replaced? This sounds like a loose or rattling idler on the timing belt. Suggest removing the upper timing belt cover to see if noise is coming from inside the timing belt cover.
You might try disabling the accessory belts sequentially to see if noise is coming from PS, Alt, or AC rotation. You can run like this for long enough to diagnose.
Would a timing belt make perfectly timed, intermittent noise? How could I disable the accessory belts? Pull fuses?
Old Jan 2, 2013 | 03:54 PM
All right! I got it fixed. It was the ABS modulator. I disconnected the ABS control unit in the truck and now no noise. Sweet easy fix and don't need ABS anyway.
Thanks again and cheers
live2rice
Sep 3, 2012 12:34 PM
jinstyle
Feb 1, 2012 07:36 PM
acauble
Jul 10, 2009 04:55 AM
sajeed
Jul 3, 2008 12:36 AM
atwood
May 1, 2006 08:59 PM
