engine noise after timing belt replaced
Old Feb 19, 2012 | 05:20 PM
mrenee's Avatar
Default engine noise after timing belt replaced
hello. I just got my timing belt/water pumped replaced on my 2005 accord ex v6. I have noticed that there is a loud squeaking/squealing noise now coming from the timing belt area. It is constant at idle and while driving. Any ideas to what this could be? Should I be driving it?
Thanks!
Old Feb 19, 2012 | 06:02 PM
It could be the timing belt idler, or timing belt auto-tensioner and/or adjuster. If this was done by someone else, I would take it back. I wouldn't recommend driving it too much for now.
Old Feb 19, 2012 | 06:36 PM
EXV6NIGHTHAWK's Avatar
I would take it back, and tell them to try again, or refund the labor charge so you can have someone else do the job. Who did this job? Dealership? Did they use OEM parts? I read something about a TSB on this issue, but I can't find it right now. Something about the water pump body being machined wrong, and causing the pulley to mount at an angle. The TSB involved adding a shim plate between the water pump and pulley.
Old Feb 19, 2012 | 06:58 PM
Lovemy97HondaAccord
Mar 5, 2014 06:04 PM
Accord01gt
Jan 8, 2012 07:40 PM
BrotherAli
Dec 22, 2011 07:18 AM
twinster2
Jul 6, 2009 09:28 AM
Tony1M
Apr 1, 2007 05:42 PM
