Oil leak after timing belt was replaced.
Old Jul 1, 2009 | 09:10 PM
twinster2's Avatar
Default Oil leak after timing belt was replaced.
Just picked my 96 Accord up from the shop for a timing belt replacement at 200K miles. Anyway, got it home and after about an hour noticed a 4 inch spot of oil on the drive way under the timing belt cover. Also noticed that when I start up the car, the external belts squeal. Pretty p*&^ off about this since it cost $400 to do the work. Anyway, I will be calling up the shop tomorrow what happened. Does anyone want to take a guess as to why it is leaking oil not and not before.
Don
Old Jul 2, 2009 | 06:56 AM
Welcome new member!
I'd let them have a chance at that first, unless you just don't trust the shop. They may have disturbed a seal on one of the shafts. Hard to say unless you want to take the time to remove the timing covers & belts.
Old Jul 3, 2009 | 09:08 PM
twinster2's Avatar
Well I took it into the shop again and they found that the counter balance seal was leaking so that replaced it. Brought it home and now I'm getting a high pitch wine from the same area. Hate to take it back but the sound was there before that replaced the timing belt.
Don
Old Jul 6, 2009 | 09:28 AM
You mean the sound was NOT there before?
High=pitched whine sounds like maybe the timing belt is too tight? Take it back again. FYI, that should be a real simple adjustment for them to do.
Lovemy97HondaAccord
Mar 5, 2014 06:04 PM
Andrew7048
Oct 7, 2012 12:12 PM
mrenee
Feb 19, 2012 06:58 PM
cjkone978
Jun 30, 2011 08:08 PM
Tony1M
Apr 1, 2007 05:42 PM
