Engine Rattling
Old May 15, 2007 | 09:53 AM
dbax89
Default Engine Rattling
Hey guys
The engine to my 1990 Honda Accord as recently developed a rattling sound in the engine, which is quite annoying and can be heard within the car whilst I'm driving. It sounds like there is a nut that has come loose and been trapped in a tin can to put it metaphorically.
I have had a look through the engine but was unable to find any loose material and dont have the equipment to really lift the car up to have a better look.
So has anybody ever had same problem or know of anything that it could be?
Cheers
Old May 15, 2007 | 10:17 AM
zexkid37's Avatar
Default RE: Engine Rattling
How many miles are on your '90? Have you ever had your valves adjusted or half you checked the valve lash recently? These engines do have a bit of valve tap more so when cold then when at operating temp.
Old May 15, 2007 | 12:05 PM
Check all the heat shields; exhaust manifold, catalytic converter, etc. for security. This can rattle and be very annoying.
Have timing belts been done? A failing tensioner could start rattling due to a dry bearing.
If noise is from under valve cover, better check immediately as you may have something bouncing around that may eventually jam and cause a problem.
live2rice
Dec 20, 2010 09:46 PM
mihalis
Feb 15, 2008 07:45 AM
Gage05
Jul 17, 2007 11:34 AM
Gage05
Dec 4, 2006 02:26 AM
nixalot
Jul 21, 2006 09:08 PM
