Engine stops + blinking key signal (1998 4cyl)
Old Aug 31, 2012 | 08:38 AM
PatBB's Avatar
Default Engine stops + blinking key signal (1998 4cyl)
Hi all.
I hope someboby can help me found what's wrong with my 1998 Honda ACCORD LX, Automatic Engine - 4 Cylinder -V-Tech Engine.
A few months ago, on rare occasion, the engine would stop while I was driving on the highway at about 100km/h. It stops just for a second then it starts back by itself.
Recently, the problem star occurring more often when I was at low speed, approaching a stop or when starting right after a stop or even when I was at a complete halt. In this situation, I had to put the car in the Park position and try to start the car. Very often it took several tries before getting the car to start.
I read several post in the forum but it looks like every situation is a little bit different than mine.
This is extra information that can help ...
-when I put the key in position II, only the radio will start, I have not other light on the console or dashboard.
-If I move the key just a little further than position 2 without starting the engine all the lights on the dash are visible and I can ear a click sound below the dash.
-Recently, the gas and break line were changed.
-I own the car for 7 years and I never changed the spark plugs or gas filter.
-The timing belt was changed at 200000KM 7 years ago.
-At Idle the engine is running below 1000rpm, just the line below 1000.
Please let me know if you need more information.
Thanks for the help.
Regards.
Old Aug 31, 2012 | 09:30 AM
doctorbee's Avatar
sounds like the ignition switch. Have you taken it in for the recall?
Old Aug 31, 2012 | 09:36 AM
PatBB's Avatar
No, I was not aware of that recall.
Is it still possible get it fixed or its to late?
Old Aug 31, 2012 | 09:43 AM
PatBB's Avatar
I found this link regarding the recall
Honda Service Bulletin - Faulty Ignition Switches.
Looks like my problem.
Now lets see if I can get it fixed under that recall ... it's 10 years old!!
Old Aug 31, 2012 | 10:35 AM
PatBB's Avatar
According to Honda the switches were changed back in 2002.
Since the symptoms are the same I thing I will go ahead and replace it.
csh217
Jun 17, 2014 05:53 PM
mchl_hoy
Sep 19, 2009 10:21 AM
thunder_x
Nov 30, 2007 12:57 PM
thunder_x
Apr 25, 2006 10:27 PM
aghigig
Nov 20, 2005 03:04 AM
