Engine Won't start
Old Feb 19, 2009 | 03:17 PM
blu_way
Exclamation Engine Won't start
1989 Honda Accord LX 2bbl carb
I was driving down the highway when my car started to lose power, a little shutter, and died while driving. I tried cranking but nothing. No clicking or sounds at all. I change the plugs, fuel filter, wires, ignition already before the incident. I recently brought an starter but still nothing. I think it is mechanical problem because all of the electrical is good. It is like the engine is lockup and wont do nothing. Someone suggested that the oil pump or oil blockage is causing the problem. If you have any suggestions, I would be very appreciated for helping.
Old Feb 19, 2009 | 03:37 PM
kornfox's Avatar
what do you mean by all the electrical is good? if you turn the key and absolutely nothing happens, i'd bet on an electrical issue. ignition, battery, alternator, etc..
Old Feb 19, 2009 | 04:53 PM
The battery is the first thing that I would test. Hook up jumper cables to see if you can get the engine to crank. Also check that all ends of both battery cables are clean and secure. Check the cable that goes from the alternator to the battery as well.
Alternatively, If you have another car, pull the battery and take it to autozone to have it tested.
Old Feb 20, 2009 | 02:54 AM
blu_way
I check the alternator, battery, igniton already. They been check and tested that they work. What engine or mechanical problem could cause this?
Old Feb 20, 2009 | 02:41 PM
deserthonda's Avatar
if you are sure that all the electrical is good you might want to chk the timing belt ,,,,,,,,,,,but if there is no clicking or sound it could also be the ignition switch..or a blown main fuse,, .....do the dash lite lite up when you turn the key on ??
Sheri6889
Jun 17, 2015 08:19 AM
thomks
Aug 15, 2006 06:43 PM
POTO
Jun 23, 2006 12:25 PM
droptail
May 17, 2005 10:37 PM
