Eratic RPM tAchometer
Old Jul 11, 2009 | 08:45 PM
Kinguvhearts's Avatar
it wont go over 5000 rpms it just stops there
Old Jul 11, 2009 | 08:57 PM
it doesnt go over 5000 rpm the needle just stays at 5 when im driving , or when i start the car the needle wont show the accurate rpm
Old Jul 11, 2009 | 09:00 PM
How is the engine running? Will the engine go past 5K?
Your problem could be the ignition control module (ICM), the wiring, or the tachometer. The easiest step to try first is what I posted before about checking the connections/wiring to the ICM.
Old Jul 11, 2009 | 09:32 PM
engine runs great doesnt seem to idle low or anything just seems fine. i just think the tachs outta wack
Old Jul 15, 2009 | 05:16 PM
jsam's Avatar
You can buy a timing belt kit on ebay for $115 (see link below). Kit is complete except for rear balance shaft cover oring (from Honda). Labor will be 5-6 hrs at shop rates. If you diy, you save the labor.
http://cgi.ebay.com/ebaymotors/New-H...ayphotohosting
Why transplant an engine of dubious origin for a known good engine?
I have no idea what "shaving the gears" means.
If AC is original, the expansion valve orings are likely leaking and possibly compressor shaft seal (look for ring of oil/dirt around compressor clutch).
Are there any other items you can think of besides the kit (from ebay) and the rear balance shaft cover O-ring that I can get from the Honda dealer? I just want to make sure I have everything on hand before starting the job. Thanks.
Old Jul 15, 2009 | 06:00 PM
19Accord97
VSS? (Vehicle speed sensor)
Old Jul 15, 2009 | 06:24 PM
  #17
That kit is complete w/ exception previously noted.
Replacing camshaft, crankshaft, and forward balance shaft seals is optional IMO. I would only replace them if they are leaking. I've seen forward balance shaft leak before, but never a crankshaft or camshaft seal.
Best bet for restoring tachometer is to remove the instrument panel and have repaired by a shop,... or live w/o a tach. It's not an essential gauge.
hotnics82
Sep 24, 2008 02:25 PM
HondaPhyco
Apr 15, 2008 10:27 AM
adstudio3d
Feb 6, 2008 08:45 AM
MALSR
Jan 22, 2007 08:23 PM
baxternick
Dec 19, 2005 12:30 AM
