evaporator removal '98 Accord
Old Jul 27, 2013 | 07:51 PM
EJV54's Avatar
Default evaporator removal '98 Accord
The txv is bad on my granddaughters accord. I am at the point where I have everything disconnected from the evap/heater housing. The evap/heater housing has a flange from the blower housing and the air distribution system housing. I need to know what to do to be able to drop out the evap/heat housing. It is free and slides with in the flanges on the blower and air distribution housings.
Old Jul 28, 2013 | 07:45 AM
I've moved this to General Tech.
I'm a bit confused at what step you are at - it is early for me.
Not sure if this will help or not?
Old Jul 28, 2013 | 09:27 PM
EJV54's Avatar
Thanks poorman212. The diagram did the trick. I missed the 10mm nut down by the drain on the housing. Removed it dropped the evaporator, installed the new txv and it cooling perfectly again. Again thanks for your help.
Old Jul 30, 2013 | 11:13 AM
Cool - for you and for the car
Edward Heffernan
Jun 11, 2014 09:00 PM
LambertJohn
Sep 8, 2013 11:19 AM
93Accord2.2
Aug 17, 2013 04:36 PM
97Auction
May 23, 2010 02:55 PM
Oct 4, 2006 04:16 AM
