EXACTLY which relay do i need?????
Old Aug 2, 2011 | 06:12 PM
tattoodad70's Avatar
Default EXACTLY which relay do i need?????
After reading some threads i have come to the conclusion i need a main relay!! I have a 1990 Accord, 4cyl, auto. I do not hear the fuel pump with key turned to position II. It has really been hot outside, and it has not started since the weather got hot. I get my parts from Oreillys Auto, and they have EFI main relay, fuel pump relay and a main relay. I do not know which one to buy, or the exact location. I recently put on new harmonic balancer, spark plugs. Payday is tomorrow and i am lost.
Old Aug 2, 2011 | 06:55 PM
Copy and paste this link into your browser. It will show you the location and how to remove the relay.
techauto.awardspace.com/mainrelaydefine.html
The relay you want is the
BWD R3265 for $59.99
or
Master Pro 2JR30 for $49.99
NOT BWD R3056 Main Relay
If you know how to solder, you can try to fix this yourself.
Old Aug 3, 2011 | 03:59 AM
Default 1990 Accord Main Relay
Thank you for the help. I will repost when job is complete and correct. This is a life saver, i have to do it before school gets underway next week.(cant make the kids walk)
Old Aug 3, 2011 | 09:32 AM
Default Working for now!!!
Installed the main relay,took about 20 min. It started up after few turns of the key. Batt. was kind of low. So far so good. Ill try starting in the heat of the day later....fingers crossed.
ag543
Apr 7, 2011 06:24 PM
wallawonder
Jun 15, 2010 12:13 AM
greg05
Aug 31, 2009 05:32 PM
Castor Troy
Apr 17, 2007 03:37 PM
noboundaries628
Nov 6, 2006 08:19 PM
