Exhaust smell coming inside car.
Old May 22, 2013 | 09:47 PM
94ex915's Avatar
Almost A Senior Member
Default Exhaust smell coming inside car.
It seems that ever since I removed my muffler I have an exhaust smell coming into the car (Only when the windows are down). But I don't think removing the muffler would cause that smell while I am driving. Or would it? Any thoughts?
Old May 23, 2013 | 06:02 PM
MessAround's Avatar
The only time I ever smelled exhaust near the front of the car as opposed to the tailpipe was when I had a rusted out hole in the exhaust near the cat. converter. But I knew this because there was a different exhaust sound like farting. Maybe you have a leak somewhere?
Old May 23, 2013 | 06:07 PM
mamtsberg's Avatar
Concurrence on the leak. Not sure about the '94 but mine has a flex pipe and that was where the leak was on mine, same symptoms, smell exhaust in the car with windows down. I didn't hear anything noticeable. I put some SeaFoam in the intake, makes the smoke and sure ceough, it was leaking right at the flex pipe just before the cat. The cat/pipe connection had a small leak as well.
Old May 23, 2013 | 07:28 PM
94ex915's Avatar
Its just weird that it started happening after I removed the muffler. I might pick up a can of SeaFoam to try that out.
Old May 23, 2013 | 08:23 PM
mamtsberg's Avatar
I could very well be that when you took the muffler off, you rattled one of the connections or something loose.
When I found the flex pipe leak, I also found the joint before and after the CAT were both leaking too, so moving the muffler around might have knocked something loose.
It doesn't take much to get that exhaust smell in the car.
Old May 23, 2013 | 10:23 PM
Old May 24, 2013 | 12:13 AM
Lightbulb Excellent Video
This Eric the Car Guy does have some of the best car dianostic and repair videos on the internet..book mark him and use his videos when you get in a fix you can't find the answer quickly here in the HAF..
Attached Thumbnails Exhaust smell coming inside car.-269049_10151401481299989_2100995541_n.jpg
Old May 24, 2013 | 02:40 PM
94ex915's Avatar
Originally Posted by PAhonda
Love his videos. Will check everything out this weekend and report back.
Elie Eyebrow
Jul 7, 2013 07:20 AM
cyberfriend
Jun 17, 2013 03:05 PM
kennilope
Dec 9, 2010 01:50 PM
guinnessmike
Aug 14, 2009 03:01 PM
aang
May 25, 2005 07:25 PM
