exterior door handle repair
Old Dec 8, 2010 | 02:58 PM
Robster's Avatar
Default exterior door handle repair
Folks,
My driver's side rear door's exterior handle does not work. Shortly before it failed completely, I had to lift it all the way up and it would open door at the last millimeter, accompanyed by a screeching sound.
Sprayed WD 40 on it, and it stopped working altogether. have to open that door from inside.
Any ideas on what it could be? I assume some sort of rod disconnected itself.
Anyway, to get at the innards, I would I have to remove the whole interior door panel. Is this a major hassle, esp. replacing the panel correctly?
One DIY repair thing I saw had you disconnecting all electrical items (some held in by clips or such). Is that absolutely necessary?
Old Dec 8, 2010 | 05:27 PM
Welcome.
First, you better tell us what car you're talking about.
Second, I'm moving this to General Tech where it belongs.
Old Dec 9, 2010 | 10:30 AM
Robster's Avatar
Default 2001 Honda Accord LX outside passenger door handle doesn't work
Sorry folks. It's the drivers side rear door handle that doesn't work.
Is getting door panel off/on a major hassle (has power locks and windows)?
Looks doable in Haynes manual, tho photos are for driver's door.
Don't want to screw it up!
Old Dec 9, 2010 | 11:48 AM
Its not too bad to remove.
rwyatt80
Jun 23, 2013 10:30 AM
mearth
Oct 14, 2012 09:50 AM
hondaman222
Jul 16, 2011 10:44 AM
te1966
Jun 30, 2010 12:23 PM
87hatchback
Aug 17, 2007 08:17 PM
