f20b misfire but dont know why please help!!!!!
Old May 19, 2013 | 06:17 PM
leos95accord's Avatar
Car has no egr and deleted from ecu.
Old May 19, 2013 | 08:03 PM
The hissing sound could be from a vacuum leak. It could explain your problems.
Ask the shop that suggested a tune up what specific items they want to do to tune up the car.
Old May 19, 2013 | 08:17 PM
Here is a good video on how to check for vacuum leaks.
Here is a video on how to check for damaged spark plug wires:
Old May 19, 2013 | 09:14 PM
We checked compression on the engine and it was good and they did a test where they put air in the engine to see if there was a leak and nothing.
Old May 20, 2013 | 06:04 PM
PA- help me here as you've prob see/heard more of these videos than I have.
To me there was a ton of valve noise, did they get the lash correct when the head was repaired?
Old May 20, 2013 | 08:27 PM
Valve lash can cause misfire?
Old May 20, 2013 | 08:42 PM
  #17
Poorman, I heard the valve noise as well. The problem with these videos is that it is hard to tell if the noise is too loud.
I think that it is a good idea to get the valves adjusted to spec. I would guess there has to be some point where a grossly misadjusted valve could cause a problem.
I'm guessing the pumping air into the engine was a leakdown test. That does not rule out a vacuum leak. I fixed the first link in my previous post for the how to find a vacuum leak video.
Old May 20, 2013 | 08:59 PM
  #18
Old May 20, 2013 | 09:01 PM
  #19
Im gonna take it to the shop sometime this week. I will let you know what it does. Thanks guys
93 honda accord
Jun 8, 2010 02:30 AM
blazeplacid
Jun 10, 2008 02:47 PM
thunder_x
Sep 19, 2006 01:01 AM
morra1221
Mar 28, 2006 03:23 PM
