F23A Swap - Automatic Transaxle issues- need help
Old Sep 29, 2008 | 06:16 PM
brintonwhalen's Avatar
Default RE: Cv's?
I dont think the spring clip engaged, come to think of it, damn
Old Sep 29, 2008 | 06:18 PM
Default RE: Cv's?
lol well im sure they are plenty lubed up right now - bet if i go jeck it up and remove the tire and dampner fork i can push it in there.
Old Sep 29, 2008 | 06:23 PM
Default RE: Cv's?
I doubt you can get enough slack to push them in place w/ the other end of axle anchored to the wheel hub. Worth a try. It takes some excess force usually to get them to fully engage. I've always had some problems w/ this enagagement, and have had to re-install the "old" snap ring when new snap ring refused to allow the joint to engage. Not the best design when tolerances are so close.
Old Sep 29, 2008 | 06:48 PM
Default RE: Cv's?
yeh wasnt able to get them in that was tough lol- i will goto the shop tomorrow and get everything in - those snap rings at autozone?
Old Sep 29, 2008 | 06:53 PM
Default RE: Cv's?
I suspect the snap rings will only be available from Honda. Check your old snap rings. Unless they are scarred or obviously damaged, I've decided its easierto reuse them. Clean the splines and clean beneath the snap ring w/ a stiff brush and some solvent. Relube and give it a go.
Old Sep 30, 2008 | 05:23 PM
Default RE: Cv's?
Well i cleaned the C/v's and it haulted the leak almost- its coming at at a very slow rate now which leads me to believe the seal is bad - but its a sustainable rate now - overall shift quality is still horrible- and the fluid was so burnt and disgusting when i drained it - i think im going to just have to accept the fast that the tranny is on its way out - so im in the market for a used F23/22 H23/22 Automatic tranny if anyone has - i would do that manual swap but this thing just needs to be my daily driver at this point.
imjason
Aug 16, 2013 12:21 PM
basket_case
Sep 15, 2012 07:50 AM
DaKiLLaMan
Jul 12, 2011 03:25 PM
92halx
Jan 12, 2007 12:07 AM
92halx
Jan 7, 2007 12:07 AM
