Fan motor
Old Apr 8, 2014 | 03:31 PM
jrock24's Avatar
Default Fan motor
My 94 EX has over heated 2 days in a row. I added water last night and filled up the radiator. I knew my cap was old and the rubber was peeling, so I replaced that. I drove to work and once I got into traffic, it over heated again. I just check the radiator and it was empty again, so I filled it and started it to check for a leak. The temp gauge got to the normal level, and I had no leaks.
Is there a way to test the fan motor, I have a feeling it is not engaging like it should. It does turn on when I turn on AC.
Old Apr 8, 2014 | 04:19 PM
Motor will usually not overheat even if fans aren't running unless you stop in traffice after driving. Even 20 mph is enough cooling air if continuous.
More likely you have a leak allowing coolant to escape. Suggest having a cold pressure leak test performed, or using rental tool from Autozone, etc to perform test yourself. You need to find leak and repair.
CDJDM07
Aug 24, 2011 09:51 AM
BOBBY-25
Jun 5, 2011 02:40 PM
ramachan9
Jul 11, 2009 11:57 PM
Equalizer
Feb 20, 2007 08:57 PM
daddy
Feb 6, 2006 02:52 AM
