Fast Idle Valve Help
Old Aug 13, 2007 | 09:53 PM
JFS321's Avatar
Default Fast Idle Valve Help
Okay, the service manual finally came today and it says that my FITV could be the cause of massive surging on cold starts. Question...I cleaned it twice (not very dirty in the first place)...does it need to be screwed in further or should I replace it? Could the wax be old and bad?
The service manual says to check air flow at lower throttle body port. There is no vacuum here at startup on my car...but a lot of vacuum at the upper port. Any ideas???
Old Aug 13, 2007 | 11:07 PM
Default RE: Fast Idle Valve Help
Hey, here is a link dealing with tightening the FITV.
Good Luck.
https://www.hondaaccordforum.com/m_62823/tm.htm
Old Aug 14, 2007 | 02:57 PM
JFS321's Avatar
Saw that and did it...it's in as far as it can go. But I can't figure out why it appears to be closed ALL the time (the bullet tip is always flush with the end of the plastic).
Can someone please confirm that on cold starts air should be sucking through the lower throttle body port?
RobinsonRicer
Jan 25, 2013 11:16 AM
jkrueger2020
Jun 25, 2012 08:12 PM
RWilliams
Jul 24, 2011 09:16 PM
89HondaLegend
Jul 5, 2006 02:02 AM
nist7
Apr 29, 2005 03:42 PM
