fast right turn signal and right hazard light
Old Dec 15, 2016 | 02:46 PM
ac4142's Avatar
Default fast right turn signal and right hazard light
hello, i'm new and i hope i can get some help. i have a 1998 honda accord ex stick and my right turn signal blinks very fast with a weak exterior light. the right hazard light blinks with a weak exterior light also. is there a part i can get to fix this myself and what do i do? thanks in advance!
Old Dec 15, 2016 | 06:14 PM
Usually a "fast blink" is because of a bad bulb. I'd start with replacing the "weak" one you speak of. Next compare and verify the same bulbs from side to side (right/pass to left/drivers) are working.
Turn on the left side blinker and walk around the car, a little darkness helps, and see/note all of the bulbs/lights that are blinking. Then turn on the right side and verify the "matching" bulbs on that side are also blinking.
Old Dec 15, 2016 | 06:44 PM
ac4142's Avatar
hi poorman, thanks for responding. in my garage all front and rear turn signals work fine except for the front passenger. it blinks fast and the light is weak. the rear passenger turn signal seems to have correct light but is also fast blinking. the hazards are fine except for weak front passenger side light. if i change out the front passenger bulb and there's no change, any idea what i should do next?
Old Dec 15, 2016 | 10:35 PM
The Toecutter's Avatar
I'd look at the ground wire connection to the body. Do you have any other burned out bulbs? Something like the TS bulbs in the dash? I'm only asking, as most systems are "balanced", and when a bulb is out, it causes an imbalance which makes the flasher unit work faster on the burned out side. This is what poorman was getting at when he asked you to check the wattage of your bulbs (that can cause an imbalance as well).
Old Dec 16, 2016 | 06:55 AM
ac4142's Avatar
thanks toecutter. none of the bulbs are burned out. the right front is just a weak light. i will get 1157A and try that. i hope that solves the problem. i appreciate all the help!
Old Dec 16, 2016 | 01:30 PM
ac4142's Avatar
poorman and toecutter, thanks a lot. new bulb through the fender splash guards. took 10 minutes. THANKS!
gary1001
Sep 4, 2015 05:33 AM
Novaknowledgenow
Jan 16, 2015 07:21 PM
Floyd Yap Singson
May 16, 2013 10:16 PM
dfeat01
Dec 10, 2007 02:49 PM
aghigig
Nov 20, 2005 03:04 AM
