FCW 03 Failure on 2013 Accord
Old Jan 23, 2016 | 09:55 AM
FerociousHonda's Avatar
Question FCW 03 Failure on 2013 Accord
Hello all,
A month ago started getting the FCW 03 Failure error (2013 Accord) after a rain storm and it hasn't gone away. Any ideas what I can do?
Thanks in advance...
Old Jan 23, 2016 | 11:33 AM
Dr. Drivability's Avatar
If that is the Forward Collision Warning system, something has blocked one or more of the sensors, or the system may need to be re-calibrated.
Check under your hood around the front bumper area for any debris.
Old Jan 24, 2016 | 07:49 PM
Post
Thanks DRD... I checked where you mention but can't find anything. From reading around the Interwebs it seems to be the camera located behind the rear view mirror.
I'm going to contact Honda support to see what they say. I did read on some forum about a software update for the radio and the FCW.
Old Jan 26, 2016 | 07:45 PM
If like some of the 16 Pilot, there might be another sensor in the grille - pointing out of the "H".
Old Jan 26, 2016 | 09:08 PM
For the 2013 Accords, only the Touring trim has the additional radar unit mounted in the front grille. It should be located closer to the passenger side of the front bumper/grille area.
Old Feb 9, 2016 | 03:42 PM
Unhappy
Thanks guys. Still no luck. Can't locate any other camera beside the one where the rear view mirror is.
Old Aug 27, 2017 | 05:43 PM
LSMoon's Avatar
Question FCW Warning
Mine started flashing that same warning today. "FCW System Failed." First I had trouble starting with the push button ignition. Finally after 5 tries the car started. Then it gave me the FCW warning and the engine, tire and a few other icons stayed lit. I didn't know if the car was about to blow up or not. It would be nice if the warnings alerted you to either stop driving immediately or tell you that it's ok to keep driving.
It's Sunday and I was 25 miles from home. I didn't want to get stuck if I could get home so I drove very carefully and parked in the garage facing out, in case I have to be towed in the morning.
I just received a recall notice yesterday regarding the battery sensor system. I'm wondering if this is related.
And as for that Forward Collision Warning System -- I think it's useless. It beeps annoyingly if there is a car 100 yards out but it doesn't utter a peep when I'm about to crash into an unseen parking curb.
Old Apr 11, 2019 | 07:47 AM
wcarter's Avatar
Hello. Same error just popped up on my 2013 Honda today. What ended up being the issue?
Old Jun 5, 2022 | 08:18 AM
ALI26's Avatar
A month ago started getting the FCW Failure error (2013 Accord) after jumping dead batterie and it hasn't gone away. Any ideas what I can do?
Cardsallday13
Jan 4, 2016 02:09 PM
gelewis
Feb 11, 2014 07:08 PM
psp800
Apr 8, 2013 08:53 PM
Deborah
Apr 3, 2013 08:21 AM
oldaccordowner
Jan 21, 2006 08:31 AM
