Feathered tire wear
Old Jan 31, 2012 | 01:45 PM
Jet sitter's Avatar
Default Feathered tire wear
I was recently at a garage to check on a "clunk" noise coming from the left front of the car. They checked and couldn't find anything loose/damaged. They then told me that because my tires were feathered, that I needed to replace the struts on all 4 corners. I did a "bounce" test on the car and it still seems as stiff as it was when it was new. I currrently have >150K on the car, should I listen to the garage and replace the struts? One more thing, I usually take the exit/entrance ramps "clover leaf" type around 70 MPH, this probably contributes to the feathering.
Old Jan 31, 2012 | 01:56 PM
With feathered tire wear the first thing I think of is alignment. Mostly toe but to a lesser extent camber. So get an alignment.
Now maybe they saw other indications like shocks leaking fluid, or balljoints being loose. Maybe you can get another shop's opinion.
Old Jan 31, 2012 | 02:25 PM
Jet sitter's Avatar
I had an upper left ball joint replaced about 5 months ago, everything else was tight. The shop didn't find any visible signs of strut damage, only the feathered tread wear. The suspension feels strong. I put my 245 pounds on all 4 corner's and performed the "bounce" test and the car was solid. I had the car aligned two years ago. Maybe I should have it done again.
Old Feb 1, 2012 | 09:47 AM
UhOh's Avatar
So there's no driving problem ... if it's not broken don't fix it.
I'd accept the feathered wear vs. the $80 alignment fee.
Rotate tires as normal, and keep pressure up; if most of the wear is on the edges your pressure is probably too low.
Would be the first thing I'd check.
When get new tires, then do the alignment with the fresh rubber.
Old Feb 2, 2012 | 07:42 AM
Jet sitter's Avatar
I agree with your conclusion, if it ain't broke, don't fix it. The car handles fine and I still have another year of service remaining on them. I'll just keep trucking along, until I purchase a new set. Than I'll have an alignment done.
bobv
Jun 16, 2008 04:55 PM
vtecHef
May 16, 2007 01:10 PM
fireballer44
Jul 25, 2006 03:22 AM
elvis
Jul 11, 2006 06:03 PM
