Fixing 'the engine miss' - '97 4cyl
Old Jul 2, 2014 | 07:34 PM
UhOh's Avatar
Default Fixing 'the engine miss' - '97 4cyl
OK, the '97 Accord has had a miss especially bad at idle with the A/C on;
wife would have to put it into N at a light to not-stall it sometimes.
OK, wife complained again to me as summer appeared, so I pulled the plug leads and two had oil on them.
New valve cover gasket, plugs and wires. Misses no more. Wife happy.
Hope your car's engine miss is as easy to fix.
Old Jul 3, 2014 | 12:46 PM
Roader's Avatar
Wife happy.
The most important part of any repair.
Old Jul 6, 2014 | 08:37 AM
moey's Avatar
There is a o-ring in the spark plug tubes it often leaks. You may want to check in a couple weeks and see if the oil has returned. Hopefully it has not. Our 96 leaks there its fairly common along with the valve cover leaking. I usually just pull the plugs every 15k miles let the oil drain into the engine and put the plugs back in. Someday Ill get around to fixing it.
Jreal
Sep 18, 2014 06:16 PM
IDHONDA
Dec 11, 2012 06:39 PM
inspector9
May 23, 2012 05:16 PM
Jasonsig
Nov 15, 2009 11:56 PM
EEL
Jun 22, 2007 10:30 PM
