Flashing oil light? What does it mean?
Old Mar 29, 2008 | 10:24 AM
MikeT's Avatar
Default Flashing oil light? What does it mean?
My 1993 4cyl F22A the other day right after start up we backed it out of the driveway, put it in drive and then the oil light started flashing. I immediately turned it off and checked the oil. It had more than the lower dot on the dip stick so I figured all was well. We started it up and there was no flashing from there on. What does the flashing mean??
Old Mar 29, 2008 | 11:59 AM
brayner's Avatar
Default RE: Flashing oil light? What does it mean?
low pressure?
Old Mar 29, 2008 | 12:32 PM
hondadude's Avatar
First off, you need to have more than the bare minimum amount of oil in the car.
A quart of oil costs way less than a replacement engine.
The usualcauses for oil light are, not enough oil to keep pressure, plugged up oil sump screen, faulty OPSU, poor electrical connection at the OPSU, andcrank main bearings are worn from driving the carlow onoil.
Old Mar 29, 2008 | 01:59 PM
MikeT's Avatar
ORIGINAL: hondadude
To be more precise than my original statement, The oil level was exactly between the upper and lower dot on the dip stick. I would never run the bare minimum of oil in my car or think that the lower dot was an acceptable level of oil in my car. This flashing is something I have never seen before so that was what I was questioning. I will add a little to get it up to the upper dot.
Old Mar 29, 2008 | 02:10 PM
sir_nasty's Avatar
The first thing I would check then is the oil pressure unit (or oil pressure switch...) it's located on the rear of the engine directly above the oil filter and has a little plastic boot around it... make sure that it's not leaking oil, it's connected and the connections are clean.
Old Mar 29, 2008 | 03:05 PM
MikeT's Avatar
I actually replaced that about three weeks ago. possibly the connector may have come loose.
Old Mar 29, 2008 | 04:57 PM
gomarlins3's Avatar
Yes, check your connection. Why did you need to change the part?
Old Mar 30, 2008 | 07:31 PM
MikeT's Avatar
I changed it in my quest to stop all the oil leaks. There was what appeared to be oil coming out from above the oil filter and someone said it might be that switch.
ohmyyikes
Jun 20, 2009 05:41 PM
stevemacleodns
Oct 29, 2008 12:29 PM
lfbs01
Feb 28, 2008 10:20 PM
FlyLow
Feb 7, 2008 01:03 PM
mussashimits
Jun 11, 2007 08:52 AM
