fluttering sound from air-mix motor assembly
Old Nov 19, 2011 | 02:20 PM
blutarsky's Avatar
Default fluttering sound from air-mix motor assembly
My 98 Accord V6 has a fluttering sound coming from the air-mix motor assembly. Seems to do it more when the cabin temp is close to the set temp. Goes away when you crank the temp up or down. I checked the linkage to the air-mix door and the cable that runs to the valve on the heater hose-both seem to be moving freely. Do these motors go bad? Should I be looking for some other cause or just replace the motor? thanks.
Old Nov 20, 2011 | 08:27 AM
Sounds are really hard on the internet....I have not heard of too many mode control motors going bad...I have heard and personally have issues with the linkage binding. Usually a good lube of the "slides" and that and I'm back in business.
Old Nov 20, 2011 | 04:52 PM
blutarsky's Avatar
I know sounds are tough to explain. The motor makes a slight sound whenever the temp is changed, even 1 degree. Now what it periodically does is makes that sound almost continuously and usually when the set temp is close to the actual temp inside the car. I'll try to lube things up and see if that takes care of it. Thanks for the reply.
earlflux
Apr 18, 2013 07:01 AM
tmarch
Dec 27, 2012 03:53 PM
Tradewind
Aug 4, 2012 11:37 AM
Tek310
Jul 29, 2011 07:46 AM
jamrock
Mar 17, 2009 10:49 PM
