front brake rotors
Old Feb 4, 2007 | 10:25 PM
ron53's Avatar
Default front brake rotors
After owning a couple of honda's I tend to do my own maintenance but one thing that really annoyed me was the front rotor configuration on my 1990 and 1995 accord models when a rotor change was due. The civic and crv had easy rotor change so I'm wondering if the 2003 accord has the same set up as the crv and civic or like the old 1990 and 1995 accord models.
Old Feb 4, 2007 | 11:13 PM
hondadude's Avatar
Default RE: front brake rotors
In '98' they wised up and changed back to a "normal" configuration like your civic and CRV had.
Old Feb 4, 2007 | 11:23 PM
RTexasF's Avatar
Super Member
Not to hijack but.......many 7th gen Accords had to have the front rotors turned right off the bat, including mine. Are they thick enough to be turned again or is it a one time deal and buy new next time?
Old Feb 5, 2007 | 01:07 AM
hondadude's Avatar
there is a measurement 'minimum thickness' spec stamped on the rotor hub.
When you turn/resurface the rotors there is less metal to dissipate the heat, so they are more likely to warp again.
Old Feb 5, 2007 | 08:37 AM
ron53's Avatar
Thanks for the reply and am real glad to hear that the configuration was changed because I think one of the accords weakneses are premature rotor warping.While I am on the subject whenever I change the rotors what brand do you suggest oem or after market.
Old Feb 5, 2007 | 01:07 PM
hondadude's Avatar
OEM or Aftermarket?
Well it's a lot of work to change those rotors, but usually parts store rotors will be okay.
I say "usually", becauseI had a run of about 6 months that every flippin rotor [Accord and Civic]I got from my aftermarketsupplier was warped right out of the box, and they won't warranty the labor only the part itself.
tmac7175
Aug 5, 2009 11:36 AM
J2Performance
Jan 25, 2008 01:02 PM
J2Performance
Jan 15, 2008 12:45 PM
benjiaccord
Mar 20, 2007 10:21 PM
deserthonda
May 12, 2006 04:06 AM
