Front driver side turn signal problem
Old Jun 11, 2012 | 03:54 PM
Damondelong's Avatar
Default Front driver side turn signal problem
Here is my problem. I drive a 2006 accord sedan se. Im the original owner, and now I have 218,000 miles on my car. My left driver side turn signal burnt out, and I just changed it now. It now blinks fast, and only when the headlights are turned off. I have made sure that this is the only light burned out. Hazards work at the correct speed. Just turn signal front and back blink fast when headlights are off. When headlights are on just the left tail light blinks fast.
Any suggestions?
Old Jun 11, 2012 | 04:19 PM
Make sure the bulb is the correct type and check the other bulbs too. If bulbs are correct type and okay, it may be the turn signal/hazard relay.
Bulb guide is here: Lamp Replacement Guide View All Bulbs
See this thread for a picture of the location.
https://www.hondaaccordforum.com/for...d-sedan-37489/
Old Jun 11, 2012 | 04:39 PM
Red bull thanks but no luck. Checked fuses and it's the correct bulb. I'm stumped
Old Jun 11, 2012 | 04:49 PM
I am referring to the relay, not the fuse.
Old Jun 11, 2012 | 05:03 PM
Go figure. I try the other bulb that came in the box, and it worked. Totally back to normal. Thanks for the help red bull
Old Jun 11, 2012 | 05:21 PM
Glad you fixed it.
x13darkmatter
Mar 3, 2013 02:52 PM
nathan5603
Sep 14, 2010 08:35 PM
bilottashii
Jun 10, 2008 12:33 PM
Cajun
Mar 31, 2008 05:20 PM
aghigig
Nov 20, 2005 03:04 AM
