Front end clunk
Old Dec 9, 2011 | 12:57 PM
pbeens000's Avatar
Default Front end clunk
2002 honda accord V6. Recently changed left hand upper ball joint/arm assembly. Now i'm hearing a faint clunk when i drive over rough roads and bumps etc. Sounds like it's coming from the right hand side now. Had a retired mechanic look at it and really did'nt detect much. Said it may be swaybar linkage,which is cheap to replace. Any idea's on common Honda issue's before i start throwing money around?????
Old Dec 9, 2011 | 02:04 PM
Recently saw a post where the strut mount bearing at top of strut was damaged and causing a clunk. Try bouncing up/down on the fender as vigorously as possible to see if you can cause the noise and hopefully trace.
Sway bar bushings where they attach to lower arm are notorious for causing clunks in turns.
googlydorken
Mar 10, 2011 05:41 AM
sapper_tom
Jan 4, 2010 06:28 AM
shamrockshooter
Jun 24, 2009 07:25 AM
rikee
May 22, 2008 01:56 PM
razcob
Nov 28, 2007 04:51 PM
