front window defrost
Old Oct 22, 2012 | 04:27 PM
Tim Grosse's Avatar
Default front window defrost
My front window only defrosts with the ac on. Any suggestions would be greatly apprieciated. Thank you
Old Oct 22, 2012 | 04:42 PM
EXV6NIGHTHAWK's Avatar
That's normal. If you want to defrost the windshield quickly, the A/C on is the way to go, especially in high humidity. It will defrost without the A/C, but it will take longer, and you will have to turn the heat up.
Old Oct 22, 2012 | 04:46 PM
Defrost only works decently (w/o AC) w/ air on Outside Air (deselect recirculation). As pointed out it's not as good as AC dehumidified air.
Old Oct 23, 2012 | 06:18 PM
"Tim" - what year is your car?
Are you adding coolant over time because it is getting low? Is the AC drain clean? If a year with a cabin air filter, when was the last time it was changed.
Yes, with the AC on the water is pulled from the air but at the same time "something" might be adding so much that you HAVE TO use the ac.........
honda123
Nov 13, 2006 05:25 PM
honda123
Nov 13, 2006 02:08 PM
Gooch
Oct 16, 2006 06:01 PM
MassAccord
Jul 24, 2006 01:11 AM
