front window problem 91 honda accord?
Old May 29, 2007 | 10:37 PM
treyshonda
Default front window problem 91 honda accord?
does anyone know why when i roll up my two front windows on my four door they go up falling foward and not straight and go outside rubber on outside. not straight up like supposed to. do they need re-glueing in track or what? please help if you know what to do about it... thanks...
Old May 30, 2007 | 12:04 PM
sir_nasty's Avatar
Default RE: front window problem 91 honda accord?
Either they need adjusted or they are out of the front or rear tracks, pop your door panel off and watch them as they go up, that will give you an idea of where they are binding and if they need to be adjusted. Make sure that the front and rear edges of the window are seated in the tracks properly, this problem is common if the window pops out of the front track.
Old May 30, 2007 | 12:22 PM
I would suspect the bolts attaching the window to the regulator are loose or missing, or regulator mounting bolts have come loose. Time to remove door panel and dig into the problem.
Edward Heffernan
Nov 10, 2012 03:54 PM
Michael Bomes
Sep 9, 2012 03:12 PM
ravenr106
Oct 21, 2011 06:08 AM
2006accordexl-passmirrorbroken
Apr 12, 2010 03:01 PM
mmazb3
Nov 26, 2007 03:16 PM
