fuel cutoff switch location
Old Oct 22, 2018 | 12:09 PM
ugeely's Avatar
Default fuel cutoff switch location
Where is the fuel cutoff switch on a 1996 Honda accord 4 cyl. v tec ex and can they be re-set ? Looked all over the web and found a mess of locations but don't see it anywhere's they have said. I think they have different models or years combined. And also ,is there a fuel pump module on this vehicle? I've replaced fuel pump and the relay under dash and pump still won't kick in.
Old Oct 22, 2018 | 02:07 PM
There is no fuel cut-off switch and no fuel pump module. You need to check for proper inputs to the connector for the main fuel relay. I don't have my shop manual in front of me, so I can't give you more specifics.
How are you verifying the fuel pump is not turning on?
Old Oct 22, 2018 | 06:53 PM
The Toecutter's Avatar
It might also be a bad G101 ground too. That one is located on the intake manifold.
Old Oct 23, 2018 | 07:41 AM
ugeely's Avatar
I made an assess panel and cover after removing back seat and trunk floor cover, hearing it would be no problem. Thank you for the information.
Old Oct 23, 2018 | 07:43 AM
ugeely's Avatar
Thank you, will be checking this out.
IWL BCNU
Aug 4, 2011 07:37 AM
Mzaman311
Aug 25, 2010 06:50 PM
WHATTHELOUIS
Feb 3, 2009 12:38 PM
pwcfan
Dec 10, 2008 09:31 AM
Trav20
Jan 28, 2007 02:56 AM
