Fuel delivery problems. Moved To Here!
Old Aug 22, 2009 | 08:11 PM
Landon
Default Fuel delivery problems. Moved To Here!
I have a 97 Honda accord LX with a f22b2 4 cylinder, automatic. The car wont start. I've done the obd2 test, and no faults detected. I have tested fuel pump (it's good), I have spark and compression. I only have 2 volts at the injectors on all 4cylinders. So my question is, what powers/controls the injectors.
Old Aug 25, 2009 | 12:37 AM
Cool Please Read The Forum Heading Before You Post
I moved it to a better resting place..Please pay attention as to where you post your things member...
Old Aug 25, 2009 | 12:59 PM
The main fuel relay powers the injectors.
Download a 94 shop manual from online manuals thread in the DIY section to see a wiring diagram.
Old Aug 25, 2009 | 02:41 PM
deserthonda's Avatar
first off chk fuse # 33 15 amp underhood fuse box............if ok,
at the main relay make sure that you got voltage at yellow/black wire.key on... if you do,, chk for battery voltage at injector resistor red wire ,,,,,,,,,,,
chk those and let us know
lordsusanoo
Aug 20, 2010 02:48 PM
dsnt flt
Dec 30, 2009 04:14 PM
btown1
Jan 13, 2008 01:24 PM
Breezy1
Dec 12, 2007 06:20 PM
casp3r9
Feb 17, 2007 02:45 AM
