Fuel Filter Leak
Old Apr 22, 2012 | 08:23 PM
clerical12's Avatar
Default Fuel Filter Leak
My girlfriend's car wouldn't start the other day. We had hoped it was a clogged fuel filter, so we changed that. And now her inlet fitting is leaking fuel. I have the copper gasket in there. Are there any tricks to stop this from leaking? I haven't really found any helpful information in regards to this problem on google.
Old Apr 22, 2012 | 08:37 PM
What year car, etc.?
Old Apr 22, 2012 | 10:15 PM
clerical12's Avatar
Sorry about that. It is a 1990 Honda Accord four door. I believe it is the LX model.
Old Apr 22, 2012 | 10:30 PM
For the fuel filter banjo fitting, there should be two new sealing washers used. The leak would most likely have to do with the washers (for example, some people have a leak due to using one washer instead of two or the washers are not the best ones). If you did use two washers and already snugged it up, then get two new sealing washers and try again. Sometimes the washers provided with aftermarket fuel filters are not the correct sealing washers. Match them up with your original washers to see if they are similar.
See the attached parts image for the position of the two washers.
Old Apr 22, 2012 | 10:37 PM
Honda's sealing washer are aluminum. So, you may want to get a couple of them from the Honda dealership to be sure.
Old Apr 22, 2012 | 11:14 PM
clerical12's Avatar
Does the banjo bolt connect the hose that runs to the engine? I am having problems with the hose that has a flange on the end of it.
Old Apr 22, 2012 | 11:53 PM
I guess I kind of misread your post due to original post mentioning the copper washer. So, the leak isn't on the banjo fitting with the two washers; but, the flared hard line bringing fuel (inlet, like you said) into fuel filter? Like shown in the following link and image.
How to Change the Fuel Filter on a 93 Honda Accord - DIY Home and Auto
Did the threads and the hard line look okay? If they do, remove the hard line again and this time while pushing the hard line in, tighten the fuel line nut and see if it still leaks.
Old Apr 23, 2012 | 07:46 AM
clerical12's Avatar
Yes it is the fuel inlet. The new filter I bought had a smaller copper gasket as well. I assumed this went with the inlet fitting but now that I think about it, the filter could have been for really any other car. I will not install the gasket and try it. I will try pushing the line and tightening the bolt at the same time. Thanks for the replies.
Old Apr 23, 2012 | 10:09 AM
That same filter probably covers a couple different cars. Sometimes, the banjo-bolt has a smaller bolt inside it. (That's for a fuel-pressure-gauge fitting.) Maybe that's what the extra gasket was for.
The supply pipe (lower-right in that picture) DOES NOT use a gasket.
rockhoundrob
Apr 11, 2014 11:41 AM
Special_K
Aug 12, 2011 04:16 PM
bjr001
Mar 5, 2010 07:31 PM
hondamecha
Jul 10, 2008 12:36 PM
davr364
Jun 19, 2006 09:37 AM
