Fuel injection cleaner..
Old Sep 19, 2007 | 01:00 PM
d_10's Avatar
Default Fuel injection cleaner..
I would like to know if i put fuel injection cleaner through the brake booster is it ok,. or will it harm the engine..and will it cleaner the injectors.
Old Sep 19, 2007 | 01:18 PM
falkore24's Avatar
Default RE: Fuel injection cleaner..
I'm not sure that has been tested, but it won't go through the injectors as only fuel goes through them. Use Seafoam for the full engine internal cleaning ..... I've never used it, but I intend to try it. It's recommended by many highly regarded HAF members.
Old Sep 19, 2007 | 01:31 PM
I've used Chevron Techron in the gas tank. If you need to clean the injectors then your favorite cleaner has to go into the gas tank.
Sucking into the manifold will clean out the inside of the manifold, butthe cleanerwon't actually go thru the injectors.
What are you trying to accomplish?
Old Sep 19, 2007 | 03:45 PM
accord4sroy's Avatar
Try Seafoam or you can find BG44K. The BG44K stuff is expensive though. And, it can only be found at a dealer. I went to a Pontiac dealer and got the BG stuff before. But, usually I use Seafoam which works well.
Old Sep 19, 2007 | 07:09 PM
ckebottle's Avatar
I agree onf seafoam too! Seafoam is great stuff, just recently did it. Follow directions on bottle and you will be happy.
Old Sep 19, 2007 | 07:11 PM
RTexasF's Avatar
Super Member
Put it in the fuel tank.........oddly enough, as the directions tell you to do.
PAhonda
May 17, 2024 03:53 PM
Draco
Oct 4, 2006 09:22 AM
thunder_x
Jul 29, 2006 09:11 PM
Jeff247
Feb 6, 2006 09:00 PM
nrangerfan
May 19, 2005 12:56 PM
