Fuel pressure ????
Old Mar 19, 2014 | 03:35 PM
MrWizard's Avatar
Default Fuel pressure ????
I have a 2007 Honda Accord EX 4cyl. and I'm getting a DTC P0171.
1. I have checked for any exhaust & vacuum leaks-none
2. Checked for any oily residue on MAF-none seen-still cleaned with electrical parts cleaner
3. Car stumbles on acceleration-won't go past 60mph
4. What should be the fuel pressure at the fuel rail be? Would a clogged fuel strainer on the main fuel pump in the tank cause this problem?
Old Mar 19, 2014 | 05:04 PM
Fuel pressure is first thing in diagnostic tree is to check fuel pressure. Measuring fuel pressure on this model appears to be difficult requiring a special hose assy w/ tee to replace the stock jumper from fuel line to injector rail. I ran into this problem w/ 01 Celica. You can make your own adapter, but a spare fuel jumper will be required (junk yard part). Fuel pressure spec from 03-06 manual was 47-54 psi.
P0171 can be either unmetered air (leak somewhere) too much air, or a blocked injector (too little fuel). I had this problem (persistent P0171) w/ 01 Celica and had to have a injector balance diagnostic performed by a local shop to find the problem. This test takes a special tool to energize each injector w/ pulses for a fixed time period and measure how much pressure drop. Even a few psi difference between injectors will cause problems. I did all the air leak investigations including several smoke tests and verified no intake air leaks, before I had the diagnostic revealing partiallly blocked injector. See youtube for videos on subject.
If you plan to diy, you should get the shop manual (automanualsource.com) for $22.
Old Mar 20, 2014 | 02:30 AM
MrWizard's Avatar
Hey Texas,
Thanks for your feedback.....I appreciate it
eduard
May 9, 2013 12:11 AM
BigOBob
Jan 1, 2012 02:47 PM
piconrule
Jul 24, 2009 02:38 PM
delt482
Jul 23, 2007 10:17 AM
cheggie
Mar 8, 2007 10:09 PM
