Fuel Pressure Banjo Bolt Size?
Old Mar 4, 2013 | 11:03 AM
RobinsonRicer's Avatar
Question Fuel Pressure Banjo Bolt Size?
I had to revise this question looking more into it.
Although the FSM says theres a service bolt, I cant find it. Theres nothing along the fuel rail other than the point where the fuel line meets the rail. I couldnt tell if the point where the bolt threads on was closed off or is open to be used for testing.
If it is, does anyone know the size? I wanna say 1/8" npt male that needs a female with possibly a hose barb end.
If that is closed off, what other point can I test the pressure at? Would the fuel filter work?
Old Mar 4, 2013 | 11:47 AM
This is the point I cant find on my car
This is the point that I'm thinking I can use instead (where you see the fuel rail attached to the fuel line, not the service bolt)
Old Mar 4, 2013 | 08:35 PM
What fuel rail are you running? I know the car is a 97 but you have a different motor in it (F23?), hence the question.
Also pic's are always nice.
Old Mar 4, 2013 | 09:06 PM
f22b1 fuel rail. I dont know why this one doesnt have it. My cars weird. But the fuel rail looks stock, theres just no service port. I know I can get a fuel pressure tester for hondas from ebay but I'm wondering if theres an easier option.
Old Mar 4, 2013 | 09:48 PM
Roader's Avatar
Autozone stores in my part of the country loan out fuel pressure testers for free. It includes a T-fitting that attaches to the top fuel filter banjo bolt.
Old Mar 4, 2013 | 10:02 PM
Ok. Thats perfect. I knew that the fitting wasnt so exclusive.
I dont know why I got so much crap on the other honda forum over this, Guess you guys are smarter :P
Old Mar 4, 2013 | 10:46 PM
Most cars have a standard schrader valve on the fuel rail, so you could rent a standard fuel pressure tester. The 90-97 accords had a metric adapter that was impossible to find. I made an adapter that worked ok, but that was a pain to do.
I think the loaner tools at the parts stores have gotten better and can be used on most cars sold in the US.
Here is a pic of the adapter. It is circled in red.
Old Mar 4, 2013 | 10:48 PM
Thats a good idea to make the adapter. I may try that eventually. Oddly enough the FSM says that there should be a service port anyways. I found the kit I need and will call tomorrow to see if I can find it or a similar one as a loaner tool.
Old Feb 1, 2015 | 08:57 PM
davntaz's Avatar
after reading this & other threads Re: fuel pressure testing. am I correct in assuming there is no shrader valve on the fuel rail to screw a fuel pressure tester to it ? & I'll need to hook it up to the banjo bolt on the fuel pressure regulator ?
Thanks for answers in advance
David aka davntaz
Old Feb 2, 2015 | 09:28 AM
I don't think it's the same for all model Accords. On 90-97 Accords there should be a blind threaded plug that can be removed to allow a fuel pressure adapter to be threaded in. See above pic circled be PAH.
The adapter would have a schrader valve male interface to connect to fuel pressure gauge.
abdga
Apr 12, 2015 08:36 PM
sgull
Jul 22, 2013 05:26 PM
theDex
Oct 14, 2012 10:49 AM
Jet sitter
Apr 7, 2012 07:29 PM
BigOBob
Jan 1, 2012 02:47 PM
