Fuel pulsation damper leaks
Old Apr 10, 2011 | 02:23 PM
MMoreira's Avatar
Default Fuel pulsation damper leaks
I took the fuel rail off to replace the o-rings on the injectors. Afterward, I pressurized the fuel system and I saw fuel streaming out the fuel pulsation damper. Is there anything I need to know about attaching it to the fuel rail?
Old Apr 10, 2011 | 02:41 PM
There should be an o-ring that seals it???
#7 in the pic_16741-PG7-005
Old Apr 10, 2011 | 02:49 PM
MMoreira's Avatar
The one I'm talking about is from the fuel line feed. It use metal washers.
Old Apr 10, 2011 | 03:07 PM
Sorry was trying to guess what you meant by "fuel pulsation damper". Yes the fuel rail uses washers. Not sure on a 2000 if there are two or not.
Old Apr 10, 2011 | 03:52 PM
MMoreira's Avatar
Father-in-law helped with the leak. There's a new problem now. The idle pulses between 1250 - 1500. Should I get a new fuel pulsation damper unit?
Old Apr 10, 2011 | 04:50 PM
Bleed the coolant. Then look in the DIY for an base idle adjust or re-learn. I'm going with re-learn, you didn't pull the fuel rail for nothing....there had to be a reason, and now it is corrected.
Old Apr 11, 2011 | 09:49 AM
MMoreira's Avatar
Is it neccessary to drain the coolant before bleeding it, or could I try forcing the air out of the upper hose to the cap?
Old Apr 11, 2011 | 11:56 AM
MMoreira's Avatar
Update, got a check engine light and code read P0505. Now since then car has been idling normal. Go figure. I'll just leave it as is. If light goes out by itself, fine by me.
abdga
Apr 12, 2015 08:36 PM
shelbydog25
Apr 16, 2009 12:04 PM
dclister
Apr 9, 2009 04:05 PM
sleep depervation
Mar 13, 2006 06:06 PM
tsblckcord
Feb 22, 2006 07:07 PM
