Fuel Pump Doesn't Always Run
Old Jul 2, 2013 | 09:46 PM
ike@cc's Avatar
Default Fuel Pump Doesn't Always Run
My 96 Accord does not always activate fuel pump relay. If I turn the key on and the D4 green light does not come on then off, it will never start. When I turn key on and the D4 light comes on and goes off, then P light blinks and fuel relay clicks it starts every time. When the D4 light fails it will not light when you put trans. in D4. I suggest you watch the D4 light, not sure what the relation between it and fuel pump relay
Old Jul 3, 2013 | 06:54 AM
Sorry, I moved your post reading as a separate problem. Appparently you were responding to OP. Unfortunately, I don't know how to return to original thread.
regards
Old Jul 3, 2013 | 04:13 PM
TH, I did the same thing last night. You can copy the post to the original thread, then delete this thread.
drewklos
Mar 31, 2014 02:18 PM
Westjoe64
Oct 15, 2012 12:11 PM
iranacre
Oct 7, 2011 09:54 AM
usefullmatter
Apr 21, 2010 06:36 AM
kissbally78
Jan 18, 2009 07:14 PM
