fuel pump relay
Old Dec 1, 2013 | 02:26 PM
marnine's Avatar
Default fuel pump relay
I have a 2004 honda accord. trying to locate the fuel pump relay. help. Thank you
Old Dec 1, 2013 | 04:04 PM
Welcome to HAF.
pretty sure the 4 and 6 cyl are the same......that being said, which one? There are actually two for the 7th gen's?
Next question, why are you looking for the relay? What issue are you having?
Old Dec 1, 2013 | 04:47 PM
There is a PGM-FI Main Relay 1 and a PGM-FI Main Relay 2.
PGM-FI Main Relay 1 is FI Main.
PGM-FI Main Relay 2 is the fuel pump relay.
PGM-FI Main Relay 2 works in conjunction with PGM-FI Main Relay 1. PGM-FI Main Relay 2 relies on a functioning PGM-FI Main Relay 1 in order to supply power to the fuel pump.
Honda TSB 07-020
But, it goes back to what is the reason you're looking for the relay.
Old Dec 2, 2013 | 08:38 AM
marnine's Avatar
my car is starving for gas and won't start. it's been a continuous problem since July. This time I let the car sit for one day and now it won't start. it's a V-4
Old Dec 2, 2013 | 08:43 AM
marnine's Avatar
Welcome to HA
my car is a v4. I've been having this continuous problem since July.. my car is starting for gas. I need to push on the gas pedal in order for it to start however I let the car sit for one day and now it won't start at all. I appreciate the help and comments
Old Dec 3, 2013 | 06:29 PM
Just me but this "sounds/reads" like something else.
I'll assume the CEL has not come on while driving?????? Please answer.
When you turn the key to "on"/pos II, the CEL should come on for a few seconds and the fule pump should prime - you have to listen really good to hear it "hum".....there is a panel in the trunk you can remove (under the carpet) and actually put you hand on the pump, when someone turns the key to "on".
Are the spark plugs up to date? I think they are good for ~110K. If not please use NGK for replacements.
greg05
Aug 31, 2009 05:32 PM
kissbally78
Jan 18, 2009 07:14 PM
ohccord
Dec 8, 2006 12:25 AM
smittyjs
Jun 24, 2006 11:22 PM
quietgiant
Apr 1, 2006 01:05 PM
