Fuel smell coming in in the inside.
Old Jun 22, 2016 | 03:22 PM
dsat's Avatar
Default Fuel smell coming in in the inside.
..although not all the time and there is no smell from the rear (where the fuel tank is). No smel/drips from under the car.
It seems like it is coming from under the engine compartment and flowing in through the drive side vents, especially when A/c is turned on.
I was told some time back that the engine valve gasket is leaking, but would it cause this smell. or could it be fuel injectors? I dont see obvious leaking. May be should publish a picture.
Old Jun 22, 2016 | 03:34 PM
shipo's Avatar
Have you been in the habit of milking the gas tank when you fill it?
I ask because doing so over a long period of time will eventually cause parts of the EVAP system to fail; one common symptom of an EVAP failure is the smell of fuel in the car.
Old Jun 22, 2016 | 03:40 PM
dsat's Avatar
No (Milking).. Also, the smell does not come from under the car near the canister. it is almost like coming from under the hood.
Old Jun 22, 2016 | 09:08 PM
rockhoundrob's Avatar
Fuel line leak? up somewhere around the engine?
Old Jun 23, 2016 | 05:57 AM
dgp1961's Avatar
Almost A Senior Member
What's "milking the gas tank?" Does that simply mean "over-filling?"
Old Jun 23, 2016 | 07:15 AM
shipo's Avatar
Yup; it means stop filling after the first click, no exceptions.
Old Jun 23, 2016 | 11:32 AM
Was there any work done on the car right before this started happening?
Old Jun 23, 2016 | 11:36 AM
dsat's Avatar
Nope. This has been happening for some time now, although as I have posted on other threads I changed the fuel tank recently but don't get any smell there.
Nor do I get smell in the rear seats. Only get it from the front and especially on the driver side when I get close to the vents on the left
Old Jun 23, 2016 | 01:20 PM
Is this the 1998 Accord you mention in other threads? It always helps to know what we're talking about.
All the air vents, even on the left side of the dashboard, feed air from the ventilation inlets which are under the windshield cowling. So the smell doesn't have to come from any particular side of the engine compartment.
The fuel supply line has a fitting on the firewall, & a hose from there to the fuel rail. Look for leaks because that's higher pressure.
Fuel might leak out where each injector pokes into the fuel rail. That's an O-ring seal at each injector.
The fuel return hose (attached to the FPR at the other end of the fuel rail) is lower pressure, but that's another place to look for leaks. If there's any restriction in the fuel return hose (say you crimped the tubing while changing the tank), then the return hose in the engine compartment is operating at a higher pressure than it's supposed to be.
Elie Eyebrow
Jul 7, 2013 07:20 AM
cyberfriend
Jun 17, 2013 03:05 PM
94ex915
May 24, 2013 02:40 PM
kennilope
Dec 9, 2010 01:50 PM
guinnessmike
Aug 14, 2009 03:01 PM
