Gas Pedal/Fan
Old Aug 12, 2006 | 07:55 PM
lyfeazone
Default Gas Pedal/Fan
My 95 accord used to run smooth, but now when i drive it the gas pedal becomes stiff, as in i have to push the sucker with force for it to go any faster, and at stops, the car starts off slow to a decent speed. Why is this happening?
One of my fans don't turn on or spin at all, i think it was the non a/c one. Why is that?
Old Aug 13, 2006 | 01:14 AM
miki's Avatar
Default RE: Gas Pedal/Fan
id say its you trottle cable.
Disconnect it from the engine & try to press the gas peddal. If its still stiff then thats the problem..
Old Aug 13, 2006 | 01:59 AM
Chiovnidca's Avatar
floor mat bunched up under the gas pedal?
Old Aug 13, 2006 | 02:06 AM
deserthonda's Avatar
ORIGINAL: Chiovnidca
you have seen them too eh ?? .. that is the first thing i would look for anytime the pedal (s ) don't feel as smooth as used to
if carpet in not interfering with pedal,, you might have a sticking throttle blade , open up the hood and use the accell cable manually at throttle plate see if it feels smooth ......if not... remove the intake tube at throttle body get some carb cleaner and clean out all the area where the plate swings open and close ,
if it feels smooth there and still stiff from pedal you might have a binding up accell cable
Old Aug 14, 2006 | 11:13 AM
HondaRacer4Vtec's Avatar
Yeah its prb the butterfly thing in the thorttle body, Buy some STP throttle body cleaner and read directions on bottle.
arcticf1re
Apr 9, 2010 10:14 PM
Vipers4Life
Dec 9, 2008 10:20 PM
gypsyman
Jun 4, 2007 05:39 PM
vindedreal
Nov 24, 2006 11:20 PM
mtruism
Jul 18, 2006 03:00 PM
