Sponsored by:
Sponsored by:
getting into gear on automatic
Old 09-21-2017, 02:37 AM
parpat's Avatar
Cool Vacuum on gear shift lever ??
As I mentioned before, was (and still are0 having trouble getting out of park..
BUT it seems that if I 'gun' the engine twice it shifts just fine..
vacuum leak maybe in brake system of actuator /
Old 09-21-2017, 07:52 AM
Dr. Drivability's Avatar
Go to Honda, spend 8 buck on a brake lamp switch and be done with it.
Old 09-21-2017, 05:17 PM
parpat's Avatar
Unhappy gear shifty
HUH, how does 'gunning the engine equate to brake switch ?
got a battery recall, so will take it in, and have em fix the problem too !
Old 09-21-2017, 06:11 PM
The shift lock is all electrical. It doesn't make sense that revving the engine fixes the problem unless you have a low voltage problem at idle.
Old 09-23-2017, 11:11 AM
Wondering if there is something up with the TPS readings?......yea, the '16 might be different but on some of the older ones, if the PCM "thinks" the gas pedal is down then it won't let you shift out of park. Just a thought
Starchyldd
06-06-2017 07:06 PM
letsclique
06-18-2016 04:29 PM
PinkFloridaFlamingos
07-28-2012 04:55 PM
turborabbit
12-10-2009 12:26 PM
98accordlx
02-11-2008 11:32 PM
Quick Reply: getting into gear on automatic
