glove box short circuited
Old Jan 3, 2012 | 08:39 PM
Mr Baron's Avatar
Question glove box short circuited
ok, i tried to connect some LEDs under the dash and i used the connection from the glove box bulb connection and the 12 volt red touched the black cable and did a small spark. now everything works fine except the tail lights, panel lights and parking lights. i have the alarm and when i press unlock/lock all the lights mentioned above work very well. i tried looking for a blown fuse and they are just fine.
its an Accord 91 LX any ideas/solutions? i need to drive at night and like that i cant
Old Jan 4, 2012 | 05:47 PM
Please double check the #23 15amp fuse in the underhood fuse panel.......
From there, power to the headlight switch, after above fuse, is the red/grn wire, the switch passes that to the red/blk when turned on.
Old Jan 4, 2012 | 08:20 PM
Mr Baron's Avatar
Thank you i wasn't reading the fuses right. it was the fuse after all.
Old Jan 4, 2012 | 08:47 PM
Coooool.
ahmad89
Jul 6, 2010 01:47 AM
qwan
May 1, 2009 09:05 AM
kumazam
May 28, 2008 12:22 PM
Yorty
Jan 19, 2008 05:59 PM
philzy87
Jul 9, 2007 07:06 PM
