go, no go for valve lash adjustment
Old Oct 1, 2011 | 07:38 PM
Search P7wI4EtZSaA on YouTube for a video to adjust the valves on an accord.
Old Oct 1, 2011 | 09:18 PM
Roader's Avatar
Originally Posted by landlover
Are you just throwing those numbers out?
No, that is the clearance (0.30mm) for my Accord's exhaust valve, and the number you quoted in your original post.
Originally Posted by Tek310
exhaust is .30mm COLD + or - .02mm your play can be .02mm not .04mm
0.30mm +/-0.02mm. So 0.32mm is the biggest clearance allowed, while 0.28mm is the smallest clearance allowed. 0.32mm - 0.28mm = 0.04mm allowable tolerance from nominal. Perhaps I shouldn't have used the word "play" when referring to tolerance; I can see how that would be confusing.
landlover, forget about "slight drag". Just use two feeler gauges. For the exhaust valves, if you CAN'T slide in a 0.32mm gauge, and you CAN slide in a 0.28mm gauge, then the clearance is 0.30mm +/- 0.01mm. Your valves will be adjusted well within spec.
Old Oct 1, 2011 | 10:53 PM
RA1525's Avatar
Smile Thanks everyone
Thank you and am not as hesitant to do this.
ibettysman35773
Apr 28, 2013 07:48 PM
ibettysman35773
Apr 28, 2013 06:40 PM
DevlinDevil
Mar 23, 2013 03:28 PM
eleiko
Jun 15, 2011 10:46 PM
huzzsaba
Dec 19, 2006 09:37 PM
