going broke need help
okay guys this yr. my '94 accord has cost me too much for the problem to not be fixed. the issue is the car will run for about a week, then outta NO where it wont stay on. The auto shop has torn my car apart. The fuel pump has been replaced, new distibutor,new starter and rebuilt transmission. The alternator is okay and battery connections are good. they have tried a new ignition switch and it didnt work. I need some help because i dont wanna give up on my H-DOG..SOMEONE PLEASE HELP!!!
So it'll start but then it dies? Any other characteristics about it? How does it die? Does it happen when you do anything (like shift into gear or turn the steering wheel)? Does it make any funny noises or does it sound like you simply turned off the key?
could it be the main relay be failing?
I have never heard of it failing in this way but I would think it is possible.
Also OP - this section you posted in is more for the engine and internal - like camshaft and piston kind of stuff. Your question belongs in GENERAL TECH - it will get more views and answers there.
on a side note it is so common for shops and backyard mechanics to throw in a fuel pump without even proper diagnostics.
I stopped by a neighbors house recently and commented that I noticed their super nice 6 gen coupe has been parked in the same spot for months.
The guy told me they couldn't drive it cause it wasn't reliable and couldn't be trusted to drive as sometimes it just will not start. He said when it wont start it is not getting fuel.
So first he got a pump from a junkyard and when it kept having the same problem he bought a new pump and still has the same problem. He said they were thinking about just selling it for real cheap just to get rid of it.
I asked him about the main relay which he had never heard of. He tried starting the car and it wouldnt start. I went under the dash and tapped the main relay and turned the key and it fired right up. He couldn't believe it. I told him to how to fix his with a solder iron (ala Eric the Car Guy Video that I watched) or buy a new one.
Think about how much money and time was wasted when the whole time it was just the Main Relay.
The original poster hasn't come back yet...
But anyway, what do the dashboard warning lights do when it dies? Go out completely? Check=engine light comes on then goes back out after 2 seconds? Or describe in gory detail what do thay do.
pakalolo
Oct 28, 2013 02:06 PM
JOE.G
Oct 28, 2012 08:38 AM
