Is this a good replacement fuel filter?
Old Mar 25, 2010 | 11:52 PM
crvone's Avatar
Default Is this a good replacement fuel filter?
So I am thinking of changing the fuel filter in my car, came across this one from Hastings. Has any one of you guys use this, is it a good repalcemnmet for Honda filter?
Fuel Filter 1994 - 1997
Honda Accord Hastings Fuel Filter Accord Hastings
HASTINGS PREMIUM FUEL FILTER, IN-LINE -- 2.94 in. O.D.; M14 x 1.5 in. inlet; M12 x 1.25 in. outlet; 4.34 in. length; With two metal washers; Comes with all metal housing and self-venting drain that adds superior structural strength; Built to meet or exceed OE specifications; Features no-bowl design that eliminates the mess and difficulty of changing plastic bowls; Has a hydroshield media that provides an average of 37 percent more holding capacity; It eliminates the need to separately vent the fuel system prior to draining; It has a water sensor port that accepts OEM sensors for easy monitoring; Easy-opening valve requires 88 percent less torque to open and close; Replaces Honda 16010-ST5-931 and Baldwin BF1193.
Old Mar 26, 2010 | 01:39 AM
Hasting filter products are just fine..They make many types of filters also..You'll do good with there products..
Old Mar 26, 2010 | 07:43 AM
Besides Hastings being good stuff, some of that description is hype. OEM Honda fuel filters are metal, not "plastic bowls", so that whole statement is bogus. I bet you'll find it's a good quality filter that's nearly identical to a dealer fuel filter.
Sounds like it includes the washers for the banjo fitting at the top of the filter. That's good, 'cause you should use new ones.
Old Mar 26, 2010 | 10:09 AM
deserthonda's Avatar
just install a factory filter,,,,,,it costs only around 25 dollars , that is a good deal for at least 30,000 miles or more
I agree with JIm.. all that crap about hasting filter this and that, is just to impress ,,
Old Mar 26, 2010 | 06:59 PM
crvone's Avatar
Thanks Guys,
I know this is a PITA job, so now need to find some crows feet and patience!
rockhoundrob
Apr 11, 2014 11:41 AM
nma_re
Jul 2, 2009 10:22 AM
draser
Jul 18, 2007 04:56 PM
Buckeye
May 8, 2005 12:41 AM
