Green Box Around "D" Blinking - Trans Trouble
Old Jan 22, 2013 | 12:12 AM
jtimc7's Avatar
Default Green Box Around "D" Blinking - Trans Trouble
After changing my oil the other day when I went to drive my 2000 Accord (111k miles) the green box around the "D" in my instrument panel was blinking. The car seemed to be struggling to get fully into gear in "D."
I let the car idle for a bit and then once it was warmed up all seemed well.
It now seems to need warming up every day or the same thing will occur.
Any thoughts? Thanks
Old Jan 23, 2013 | 08:29 PM
When was the trans fluid last changed.....and when it was, what fluid was used?
Old Jan 23, 2013 | 10:23 PM
jtimc7's Avatar
I got the car used and have not changed the trans fluid. What fluid do you think is best?
Thanks poorman...
Old Jan 23, 2013 | 10:37 PM
Only use Honda ATF. Drain and refill. It takes about 3 quarts. Do not have the transmission flushed.
Here is a good video on how to do it:
EDIT: When I said flushed, I mean hooking a machine to the transmission and forcing the old fluid out. The "flush" referred to in the video is the drain, refill, drive. Then repeat for a total of 3 drain/refills.
Old Jan 25, 2013 | 11:02 PM
jtimc7's Avatar
Thanks everyone! Change of fluid fixed the problem. I used ATF-DW1. Lesson learned.
Old Jan 27, 2013 | 09:11 AM
Good to know it is doing better.....Thanks for the update.
Old Jun 13, 2013 | 12:55 AM
jtimc7's Avatar
Well, I spoke to soon. I have changed the trans fluid twice now using the ATF-DW1. I seem to get about 6 weeks of normal shifting and the original problem comes back. The original problem was this:
"the green box around the "D4" in my instrument panel was blinking. The car seems to be struggling to get fully into gear in "D4."
If I let the car idle for a bit and get warmed up all seems well.
It now seems to need warming up every day or the same thing will occur."
Any thoughts?
Old Jun 13, 2013 | 11:57 AM
The blinking D4 light means a trans code is stored.
Is Check Engine Light on also? If yes, you can extract the codes w/ Obd2 scanner.
If not, you may need to use the obd1 procedure documented in DIY forum to extract stored trans codes. Codes would be blinked by the D4 light.
toicy4ya
Feb 28, 2011 04:56 PM
mrbaysick
Dec 15, 2008 06:07 PM
badxdawgx818
Jul 19, 2007 06:00 PM
MassAccord
Mar 10, 2006 08:44 PM
