Griding when turning hard on 96 Accord
Old Nov 12, 2007 | 03:54 PM
matts8008
Default Griding when turning hard on 96 Accord
I just bought a 96 Accord and had it aligned and new tie rod ends installed while out of town. About 50 miles down the road I noticed that when turning hard to the left I hear a grinding (metal on metal noise). This only happens when turning as hard as possible to the left. If I let up just an inch the noise goes away.
Any ideas? I looked underneath and everything looks ok...I can't see anything touching that shouldnt be touching.
Old Nov 12, 2007 | 04:00 PM
falkore24's Avatar
Default RE: Griding when turning hard on 96 Accord
It could be a lot of things ...... since the tie-rods were recently worked on, I'd look for rubbing or wear around them. Could also be the brakes if not installed properly or out of adjustment.
My avice is to bring it to the mechanic that just worked on it and tell him the problem. You may be entitled to a freebie!
Old Nov 12, 2007 | 05:13 PM
nafango2's Avatar
Does it only happen when the wheel is turned all the way to where it locks or just when you make a sharp turn?
Old Nov 13, 2007 | 04:09 AM
2POINTautO's Avatar
See if the inner side of the wheel (rim) is rubbing on the tie rod or something, there should be a witness mark (scratch around the wheel). Maybe the tie rod is pushing on the brake rotor backing plate ???
Sounds like the alignment is not symmetrical, is the steering wheel straight.
Old Nov 13, 2007 | 10:34 AM
klrspz's Avatar
If it's FWD, what about CV Joints?
I had CV joints go out on my VW Rabbit, and it sounded like grinding (we originally thought it was wheel bearings); turned out the boot was ripped on the top and had basically deteriorated inside.
b8man
Jan 2, 2018 09:25 AM
huhdo
Aug 30, 2012 09:06 PM
SoCalMike
Jul 2, 2007 01:04 PM
matta2002
Jun 5, 2007 07:51 PM
coronny
Mar 31, 2007 02:38 AM
